Off The Water
Watering Hole
Need to learn brazing
<blockquote data-quote="S&amp;amp;MFISH" data-source="post: 182500" data-attributes="member: 1229"><p>I've done some brazing before. It's just like soldering,only your using brass instead of lead or silver. You'll be working with higher temps,so watch out so the you don't overheat. Also,make sure everything is 'clean'. That's the extent of my knowledge.You probably want to do some practicing before you do the real thing to get the hang of it. Hope this helps a little.</p></blockquote><p></p>
[QUOTE="S&MFISH, post: 182500, member: 1229"] I've done some brazing before. It's just like soldering,only your using brass instead of lead or silver. You'll be working with higher temps,so watch out so the you don't overheat. Also,make sure everything is 'clean'. That's the extent of my knowledge.You probably want to do some practicing before you do the real thing to get the hang of it. Hope this helps a little. [/QUOTE]
Off The Water
Watering Hole
