Off The Water
Watering Hole
New boat heading back to the dealer
<blockquote data-quote="GYPSY400" data-source="post: 323423" data-attributes="member: 8599"><p>Yes this boat is under rated.. I was looking at one in 2011 and the rating was 25 for tiller, 30 with the side console.. Which is still pretty conservative.. Having a 15hp max rating is ridiculous as 15 should be the minimum.. </p><p>I can't really offer much help with your motor troubles though.. But changing the prop and adding a whale tale is bullshit! If you can redline the motor with the 8p, the 9p should be the prop to use. Honestly I think the problem is the engine not putting out 15hp..</p></blockquote><p></p>
[QUOTE="GYPSY400, post: 323423, member: 8599"] Yes this boat is under rated.. I was looking at one in 2011 and the rating was 25 for tiller, 30 with the side console.. Which is still pretty conservative.. Having a 15hp max rating is ridiculous as 15 should be the minimum.. I can't really offer much help with your motor troubles though.. But changing the prop and adding a whale tale is bullshit! If you can redline the motor with the 8p, the 9p should be the prop to use. Honestly I think the problem is the engine not putting out 15hp.. [/QUOTE]
Off The Water
Watering Hole
