Boat House
new member... new boat
<blockquote data-quote="spotco2" data-source="post: 233190" data-attributes="member: 6117"><p>Congrats on the boat! That's a good looking set up and should be pretty fishable as it sits.</p><p></p><p>If you want to drop that front seat remove the front deck, add a piece of plywood to the floor and mount the pedestal to it where you feel comfortable.</p><p></p><p>The accessory port is simple and just needs a couple of wires ran to the battery with an inline fuse.</p><p></p><p>I'm not sure about hooking up the charging circuit but it should be simple if you can find a schematic of the motor on line.</p><p></p><p>Just remember to solder connections, seal with heat shrink tubing and use a dab of dielectric grease on connectors when dealing with boats to keep as much corrosion out of the connection as possible.</p></blockquote><p></p>
[QUOTE="spotco2, post: 233190, member: 6117"] Congrats on the boat! That's a good looking set up and should be pretty fishable as it sits. If you want to drop that front seat remove the front deck, add a piece of plywood to the floor and mount the pedestal to it where you feel comfortable. The accessory port is simple and just needs a couple of wires ran to the battery with an inline fuse. I'm not sure about hooking up the charging circuit but it should be simple if you can find a schematic of the motor on line. Just remember to solder connections, seal with heat shrink tubing and use a dab of dielectric grease on connectors when dealing with boats to keep as much corrosion out of the connection as possible. [/QUOTE]
Boat House
