Boat House
New Tinny....and questions
<blockquote data-quote="lbursell" data-source="post: 168808" data-attributes="member: 3905"><p>White and Gray Jeep + Gray Moter + White Trailer = Gray Hull, Light Gray Carpet and White Trim.</p><p></p><p>Doing the entire boat with spray cans will get expensive. If you don't have a sprayer and don't want to turn your garage into a spray booth, I'd suggest rollers with a color you can match with spray cans. Then you can get 98% of the boat painted with the rollers and the other 2% (nooks and crannies, tight corners, etc) with the spray cans. Also, the spray cans are good for touch ups later on. Tractor Supply has their Farm Implement Paint in both cans with lids and spray cans if you want to match colors.</p></blockquote><p></p>
[QUOTE="lbursell, post: 168808, member: 3905"] White and Gray Jeep + Gray Moter + White Trailer = Gray Hull, Light Gray Carpet and White Trim. Doing the entire boat with spray cans will get expensive. If you don't have a sprayer and don't want to turn your garage into a spray booth, I'd suggest rollers with a color you can match with spray cans. Then you can get 98% of the boat painted with the rollers and the other 2% (nooks and crannies, tight corners, etc) with the spray cans. Also, the spray cans are good for touch ups later on. Tractor Supply has their Farm Implement Paint in both cans with lids and spray cans if you want to match colors. [/QUOTE]
Boat House
