Off The Water
Watering Hole
newbie -NEEDS ADVICE- winter storage /maintenance-do list
<blockquote data-quote="earl60446" data-source="post: 371069" data-attributes="member: 4469"><p>Sybil</p><p>I would not wrap that charger up or bag it, it can get hot and needs ventilation.</p><p>Use 80-90 weight marine gear oil for the lower unit, get a big screwdriver (BFS) that fits the screw perfect, file / grind the screwdriver if needed to make it fit, then if needed, use a wrench to help you put some torque on the screw while pushing in hard. Avoid stripping that bugger. Refill from the bottom.</p><p>Don't worry about the trolling motor except maybe security wise.</p><p>niblet = grease zert</p><p>I like your attitude about doing it yourself, then you know it was done right.</p><p>We don't dress fish, we filet or clean them. <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite1" alt=":)" title="Smile :)" loading="lazy" data-shortname=":)" /> </p><p>Tim</p></blockquote><p></p>
[QUOTE="earl60446, post: 371069, member: 4469"] Sybil I would not wrap that charger up or bag it, it can get hot and needs ventilation. Use 80-90 weight marine gear oil for the lower unit, get a big screwdriver (BFS) that fits the screw perfect, file / grind the screwdriver if needed to make it fit, then if needed, use a wrench to help you put some torque on the screw while pushing in hard. Avoid stripping that bugger. Refill from the bottom. Don't worry about the trolling motor except maybe security wise. niblet = grease zert I like your attitude about doing it yourself, then you know it was done right. We don't dress fish, we filet or clean them. :) Tim [/QUOTE]
Off The Water
Watering Hole
