Boat House
Newer Tracker Grizzlys
<blockquote data-quote="skipper123" data-source="post: 434653" data-attributes="member: 6070"><p>From what I understand that Merc is made by Tohatsu as all Mercs under 40HP and yep Tohatsu makes a fine motor and if you get the Tohatsu name on the side it has a five year warranty and a couple hundred less coins depending on HP. I saved quite a bit on a 30 HP Tohatsu branded motor bought it in the box mounted the motor and tiller myself as well as checking everything at start up to make sure it was done right. The Merc I looked at would have to be installed on my boat at the dealer by a high school kid learning on my motor. This is my 2nd Tohatsu and so far have not replaced so much as a spark plug and the first motor only had one. Keep the oil changed don't run ethanol gas in it and run the piss out of it.</p></blockquote><p></p>
[QUOTE="skipper123, post: 434653, member: 6070"] From what I understand that Merc is made by Tohatsu as all Mercs under 40HP and yep Tohatsu makes a fine motor and if you get the Tohatsu name on the side it has a five year warranty and a couple hundred less coins depending on HP. I saved quite a bit on a 30 HP Tohatsu branded motor bought it in the box mounted the motor and tiller myself as well as checking everything at start up to make sure it was done right. The Merc I looked at would have to be installed on my boat at the dealer by a high school kid learning on my motor. This is my 2nd Tohatsu and so far have not replaced so much as a spark plug and the first motor only had one. Keep the oil changed don't run ethanol gas in it and run the piss out of it. [/QUOTE]
Boat House
