Motors
No spark problem
<blockquote data-quote="Pappy" data-source="post: 438223" data-attributes="member: 3278"><p><span style="font-size: 18px">Check the gear lube and replace the impeller at the very least. </span></p><p><span style="font-size: 18px">The floats were cork and you have a chance it will be good to go. On that engine, with the lower cowl off you can pull the carb bowl and see what you have to deal with. </span></p><p><span style="font-size: 18px">Pull the cap off the tank and make sure the vent (tiny hole) is open all the way through. A fine wire should go all the way through. Free flow some fuel through the copper line to make sure it is clean and clear. </span></p></blockquote><p></p>
[QUOTE="Pappy, post: 438223, member: 3278"] [size=5]Check the gear lube and replace the impeller at the very least. The floats were cork and you have a chance it will be good to go. On that engine, with the lower cowl off you can pull the carb bowl and see what you have to deal with. Pull the cap off the tank and make sure the vent (tiny hole) is open all the way through. A fine wire should go all the way through. Free flow some fuel through the copper line to make sure it is clean and clear. [/size] [/QUOTE]
Motors
No spark problem
