Electrical
On Board Battery Chargers
<blockquote data-quote="Rivernut" data-source="post: 467834" data-attributes="member: 22517"><p>Its mot the humidity in small compartments that kills sealed battery chargers,its the heat. This is my 4 battery Stealth charging system. It is about 20 years old. It can be used with 12, 24, or 36 volt trolling motor systems. It charges my three trolling motor batteries with 40 Amps from the engine’s alternator or a traditional battery charger or even from solar/wind power. I mounted it in the open in my V-8 jet boat rear compartment. It gets plenty of air flow and the aluminum framing acts as a heat sink. It is small, not much larger than a sandwich and only a few pounds. And because it charges on the fly the batteries don’t sulfate as much and last much longer (service life) Best battery charger I’ve run across.</p><p>[ATTACH=full]102505[/ATTACH]</p></blockquote><p></p>
[QUOTE="Rivernut, post: 467834, member: 22517"] Its mot the humidity in small compartments that kills sealed battery chargers,its the heat. This is my 4 battery Stealth charging system. It is about 20 years old. It can be used with 12, 24, or 36 volt trolling motor systems. It charges my three trolling motor batteries with 40 Amps from the engine’s alternator or a traditional battery charger or even from solar/wind power. I mounted it in the open in my V-8 jet boat rear compartment. It gets plenty of air flow and the aluminum framing acts as a heat sink. It is small, not much larger than a sandwich and only a few pounds. And because it charges on the fly the batteries don’t sulfate as much and last much longer (service life) Best battery charger I’ve run across. [ATTACH type="full" alt="DF8B792F-A18A-4CD9-A443-00818EA16936.jpeg"]102505._xfImport[/ATTACH] [/QUOTE]
Electrical
