Motors
please help with idle issue
<blockquote data-quote="Pappy" data-source="post: 265945" data-attributes="member: 3278"><p>The engine will pull air around the openings for the throttle shaft. When you spray around this area the engine will change...they all will. You can start almost any carbureted two stroke and see the same thing you "found" with yours. Try the mixture screw first.</p></blockquote><p></p>
[QUOTE="Pappy, post: 265945, member: 3278"] The engine will pull air around the openings for the throttle shaft. When you spray around this area the engine will change...they all will. You can start almost any carbureted two stroke and see the same thing you "found" with yours. Try the mixture screw first. [/QUOTE]
Motors
