Boat House
Prep for aluminum before carpet
<blockquote data-quote="Johnny" data-source="post: 374428" data-attributes="member: 13599"><p><strong>To answer your question</strong> - - - no, you do not have to remove every spec </p><p>of old adhesive. Just get the loose stuff off, and follow the directions on</p><p>the can of adhesive you decide to use. </p><p>Personally, I find that the exterior/outside grade of carpet glue is the easiest to use vs the aerosol type.</p><p>Put it on with a trowel with 1/8" notches like you would do on a house floor.</p><p>or, for a small area, take a piece of plastic or stiff cardboard and cut some</p><p>notches in it with a knife or scissors and spread it out as per instructions on the container.</p><p>The Weldwood contact adhesive that you show will work just fine when applied properly. (follow the directions on the can)</p><p></p><p>don't over think it !! you are doing a BOAT - not your living room.</p><p></p><p></p><p></p><p></p><p></p><p>jus my dos centavos</p></blockquote><p></p>
[QUOTE="Johnny, post: 374428, member: 13599"] [b]To answer your question[/b] - - - no, you do not have to remove every spec of old adhesive. Just get the loose stuff off, and follow the directions on the can of adhesive you decide to use. Personally, I find that the exterior/outside grade of carpet glue is the easiest to use vs the aerosol type. Put it on with a trowel with 1/8" notches like you would do on a house floor. or, for a small area, take a piece of plastic or stiff cardboard and cut some notches in it with a knife or scissors and spread it out as per instructions on the container. The Weldwood contact adhesive that you show will work just fine when applied properly. (follow the directions on the can) don't over think it !! you are doing a BOAT - not your living room. jus my dos centavos [/QUOTE]
Boat House
