Motors
Problem with 9.9 Johnson carb.
<blockquote data-quote="dougdad" data-source="post: 40236" data-attributes="member: 274"><p>Magg. If you left any old fuel in the carb at all, as bass said it prob. varnished, then when you put new gas to it the varnish broke loose and pluged everything up. A good carb. cleaning should do the trick then when you store it this fall be shure to run most of the gas out then put some Stabill in and run it out, this will prevent the varnish buildup in the future. This is a very common thing among small engines of all types. You will find stabill works on all engine and fuel systems. I been usingit for years and sware by it.</p></blockquote><p></p>
[QUOTE="dougdad, post: 40236, member: 274"] Magg. If you left any old fuel in the carb at all, as bass said it prob. varnished, then when you put new gas to it the varnish broke loose and pluged everything up. A good carb. cleaning should do the trick then when you store it this fall be shure to run most of the gas out then put some Stabill in and run it out, this will prevent the varnish buildup in the future. This is a very common thing among small engines of all types. You will find stabill works on all engine and fuel systems. I been usingit for years and sware by it. [/QUOTE]
Motors
