Motors
push button start
<blockquote data-quote="FerrisBueller" data-source="post: 322387" data-attributes="member: 11145"><p>Like the other guys said, it's a fairly easy process, you just need to make sure you know the wiring. I converted mine from a push-button setup to a keyed ignition so I basically did the opposite. Make sure you know the wiring is correct though otherwise you could fry some parts and cause some damage, and its usually not cheap.</p></blockquote><p></p>
[QUOTE="FerrisBueller, post: 322387, member: 11145"] Like the other guys said, it's a fairly easy process, you just need to make sure you know the wiring. I converted mine from a push-button setup to a keyed ignition so I basically did the opposite. Make sure you know the wiring is correct though otherwise you could fry some parts and cause some damage, and its usually not cheap. [/QUOTE]
Motors
push button start
