Boat House
Question(s) on Hull Corrosion
<blockquote data-quote="PSG-1" data-source="post: 365529" data-attributes="member: 6937"><p>That's poultice corrosion, from being in contact with a wet surface, such as carpet or wood.</p><p>Use a stainless wire brush to remove the excess, then treat with ospho (phosphoric acid) Then use self-etching primer, or zinc chromate primer, followed up with paint....or preferably, good bottom paint like Trilux 33.</p></blockquote><p></p>
[QUOTE="PSG-1, post: 365529, member: 6937"] That's poultice corrosion, from being in contact with a wet surface, such as carpet or wood. Use a stainless wire brush to remove the excess, then treat with ospho (phosphoric acid) Then use self-etching primer, or zinc chromate primer, followed up with paint....or preferably, good bottom paint like Trilux 33. [/QUOTE]
Boat House
