Boat House
raising transom
<blockquote data-quote="G Lap" data-source="post: 236723" data-attributes="member: 6268"><p>If you don't have to go up too much, you can just block up your motor. I used two pieces of 1" sq aluminum tubing set side by side, between the top of the transom and the bottom of where the motor sits on the transom. It raised my outboard up just enough to get the anti-cavitation plate even with the bottom of the hull. If your clamps get close to the top of the transom, I would definetly bolt the motor down though.</p></blockquote><p></p>
[QUOTE="G Lap, post: 236723, member: 6268"] If you don't have to go up too much, you can just block up your motor. I used two pieces of 1" sq aluminum tubing set side by side, between the top of the transom and the bottom of where the motor sits on the transom. It raised my outboard up just enough to get the anti-cavitation plate even with the bottom of the hull. If your clamps get close to the top of the transom, I would definetly bolt the motor down though. [/QUOTE]
Boat House
raising transom
