Boat House
Remove or Leave this Foam?
<blockquote data-quote="onthewater102" data-source="post: 385265" data-attributes="member: 13702"><p>yup - buy a 50' roll of aluminum chimney flashing - very inexpensive, it's very thin, easy to work with, and you can partition those sections off. If you need to rivet two pieces together to make it wider no biggie, just cover the joint well with duct-tape so the foam doesn't get through it.</p></blockquote><p></p>
[QUOTE="onthewater102, post: 385265, member: 13702"] yup - buy a 50' roll of aluminum chimney flashing - very inexpensive, it's very thin, easy to work with, and you can partition those sections off. If you need to rivet two pieces together to make it wider no biggie, just cover the joint well with duct-tape so the foam doesn't get through it. [/QUOTE]
Boat House
