Boat House
Removed livewell - hole drains to bottom of boat
<blockquote data-quote="nccatfisher" data-source="post: 450548" data-attributes="member: 10811"><p>If you really want to make it impervious to water just cut another aluminum disc the size if the scupper on the bottom in the 1/8" thick range. Drill the three holes in the pattern of the disc and use ss machine screws and poly lock nuts. Get some good gasket material and make a gasket and then sandwich the whole thing together sealing it well with 5200. I'll promise you it will not leak and you will have one heck of a time getting it off once it seals.</p></blockquote><p></p>
[QUOTE="nccatfisher, post: 450548, member: 10811"] If you really want to make it impervious to water just cut another aluminum disc the size if the scupper on the bottom in the 1/8" thick range. Drill the three holes in the pattern of the disc and use ss machine screws and poly lock nuts. Get some good gasket material and make a gasket and then sandwich the whole thing together sealing it well with 5200. I'll promise you it will not leak and you will have one heck of a time getting it off once it seals. [/QUOTE]
Boat House
