Boat House
Replacement for Silicon
<blockquote data-quote="tucker99" data-source="post: 476965" data-attributes="member: 22024"><p>To finish this up, I researched this because I wasn't looking forward to digging out all the silicone I used. Seems the corrosion thing was the case a long time ago. Newer silicone doesn't use an acid cure. I found this quote from a Temco rep:</p><p></p><p>"...that's a myth to a certain degree - what they are referring to is "acid cure" silicone - old 50-60 technology - the neutral cure silicones do not react with aluminum. Consider every high rise aluminum frame/glass building in the world is sealed with neutral cure silicone for the last 30 years."</p></blockquote><p></p>
[QUOTE="tucker99, post: 476965, member: 22024"] To finish this up, I researched this because I wasn't looking forward to digging out all the silicone I used. Seems the corrosion thing was the case a long time ago. Newer silicone doesn't use an acid cure. I found this quote from a Temco rep: "...that's a myth to a certain degree - what they are referring to is "acid cure" silicone - old 50-60 technology - the neutral cure silicones do not react with aluminum. Consider every high rise aluminum frame/glass building in the world is sealed with neutral cure silicone for the last 30 years." [/QUOTE]
Boat House
