Boat House
Seat flotation foam wood facing
<blockquote data-quote="WV1951" data-source="post: 448462" data-attributes="member: 23206"><p>Working on my 1977 Mirrocraft, it appears that the flotation foam under the bench seats has a very thin piece of wood on the front and back sides to protect it. Something like Luan plywood or maybe even a bit thinner. I discovered this when I lifted the carpet that wraps the seats. The bottom of the wood is showing some rot and didn't know if it was removable without tearing away the foam so I could put new in.</p><p>My initial findings is that the wood is firmly attached to the foam. Don't know if it will come out without pulling some of the foam with it.</p><p>Anyone ran across this?</p></blockquote><p></p>
[QUOTE="WV1951, post: 448462, member: 23206"] Working on my 1977 Mirrocraft, it appears that the flotation foam under the bench seats has a very thin piece of wood on the front and back sides to protect it. Something like Luan plywood or maybe even a bit thinner. I discovered this when I lifted the carpet that wraps the seats. The bottom of the wood is showing some rot and didn't know if it was removable without tearing away the foam so I could put new in. My initial findings is that the wood is firmly attached to the foam. Don't know if it will come out without pulling some of the foam with it. Anyone ran across this? [/QUOTE]
Boat House
