Motors
shaft conversion evinrude 25hp
<blockquote data-quote="Whoopbass" data-source="post: 146044" data-attributes="member: 2243"><p>Look for the sticker on the transom mounting bracket. The model # is right next to the serial #. It will start with an "E" since its an Evinrude.</p><p>If the sticker is gone then pop the cowl off and there will be a round nearly flat silver dollar size plug/cover on the block with the #'s stamped into it. Look left side of the motor near the back higher up. The left side is when your standing in front of the motor.</p><p>If you can't find nothing then post a pic of the motor.</p></blockquote><p></p>
[QUOTE="Whoopbass, post: 146044, member: 2243"] Look for the sticker on the transom mounting bracket. The model # is right next to the serial #. It will start with an "E" since its an Evinrude. If the sticker is gone then pop the cowl off and there will be a round nearly flat silver dollar size plug/cover on the block with the #'s stamped into it. Look left side of the motor near the back higher up. The left side is when your standing in front of the motor. If you can't find nothing then post a pic of the motor. [/QUOTE]
Motors
