Boat House
Small cleat
<blockquote data-quote="simbelle" data-source="post: 322567" data-attributes="member: 10384"><p>not sure were your mounting it but seems like it would be eaasy enough to make one, take a piece of 1/4 or 1/2 inch flat stock drill a couple holes in it then screw threw it with a nuts between the stock and the boat...or you could use nuts and bolts....or yoou could make it even smaller by only using one nut or spacer or whatever, you could even JB Weld the nut or spacer into place. Just a thought.</p></blockquote><p></p>
[QUOTE="simbelle, post: 322567, member: 10384"] not sure were your mounting it but seems like it would be eaasy enough to make one, take a piece of 1/4 or 1/2 inch flat stock drill a couple holes in it then screw threw it with a nuts between the stock and the boat...or you could use nuts and bolts....or yoou could make it even smaller by only using one nut or spacer or whatever, you could even JB Weld the nut or spacer into place. Just a thought. [/QUOTE]
Boat House
Small cleat
