Motors
Speaking of Johnsons.....
<blockquote data-quote="nomowork" data-source="post: 218210" data-attributes="member: 6029"><p>Pulled the lower unit and shot water up the uptake tube. Nothing coming out of the side plate near the pee hole so worked some string trimmer line down the hole and worked a clothes hanger wire up from the bottom. After many attempts and encouraging four lettered words I was able to shoot water up the pipe and out of the side plate area. </p><p></p><p>Not having a new gasket, I used some Form-A-Gasket sealant to install the side plate and will let it cure for a couple of days then try to shoot water up the pipe again.</p></blockquote><p></p>
[QUOTE="nomowork, post: 218210, member: 6029"] Pulled the lower unit and shot water up the uptake tube. Nothing coming out of the side plate near the pee hole so worked some string trimmer line down the hole and worked a clothes hanger wire up from the bottom. After many attempts and encouraging four lettered words I was able to shoot water up the pipe and out of the side plate area. Not having a new gasket, I used some Form-A-Gasket sealant to install the side plate and will let it cure for a couple of days then try to shoot water up the pipe again. [/QUOTE]
Motors
