Boat House
Spray in foam for boats?
<blockquote data-quote="acwd" data-source="post: 241558" data-attributes="member: 7495"><p>I plan on running wires to the back anyway so it will be put in plastic pipe from the front to the back. I have been thinking about how I could make the foam removable. Thought about putting some plastic in there and spraying the foam on that then cover the top before it dries. Also thought about a way to raise it up off the floor of the boat so water can go under it and the foam doesnt have to sit in the water in case it gets a leak or rain gets in the boat. I plan on spraying the inside of the bottom of the boat with bed liner. </p><p></p><p>Steve</p></blockquote><p></p>
[QUOTE="acwd, post: 241558, member: 7495"] I plan on running wires to the back anyway so it will be put in plastic pipe from the front to the back. I have been thinking about how I could make the foam removable. Thought about putting some plastic in there and spraying the foam on that then cover the top before it dries. Also thought about a way to raise it up off the floor of the boat so water can go under it and the foam doesnt have to sit in the water in case it gets a leak or rain gets in the boat. I plan on spraying the inside of the bottom of the boat with bed liner. Steve [/QUOTE]
Boat House
