Stripping Paint?! (Picture Added)
<blockquote data-quote="Clear Solution" data-source="post: 339770" data-attributes="member: 13006"><p>I ran a chemical stripper on mine, one app did the job on most spots- some places took 2-3x. I put it one, let it cooks for 30mins and hit it with the pressure washer. Not a lot of pressure, but enough to blew the softened paint off. This got the hull to appx 70% clean.</p><p></p><p>Then I hit every inch with 220grt sanding pads on the DA sander. This took it to appx 95% clean </p><p></p><p>The rivet heads and welded seams got wire brushed. I alternated between a 6" fine wheel on the angle grinder, a coarse cup on the AG, and a full fine cup in the drill. Stubborn spots got a small shot of heat from the torch to soften the paint, and then some wheel. This took me to 98% or better. </p><p></p><p>All said and done, I've got about 15hrs in stripping a 17' flat bottom.</p></blockquote><p></p>
[QUOTE="Clear Solution, post: 339770, member: 13006"] I ran a chemical stripper on mine, one app did the job on most spots- some places took 2-3x. I put it one, let it cooks for 30mins and hit it with the pressure washer. Not a lot of pressure, but enough to blew the softened paint off. This got the hull to appx 70% clean. Then I hit every inch with 220grt sanding pads on the DA sander. This took it to appx 95% clean The rivet heads and welded seams got wire brushed. I alternated between a 6" fine wheel on the angle grinder, a coarse cup on the AG, and a full fine cup in the drill. Stubborn spots got a small shot of heat from the torch to soften the paint, and then some wheel. This took me to 98% or better. All said and done, I've got about 15hrs in stripping a 17' flat bottom. [/QUOTE]
