Boat House
Sureply plywood
<blockquote data-quote="smackdaddy53" data-source="post: 366094" data-attributes="member: 10154"><p>1/8" aluminum is what you need. Sure it is more expensive but not bad considering it will last forever. I see a lot of plywood used in builds but I don't care what you put on it it will eventually rot and you will be doubling up on labor. The best thing about aluminum is you can cut it with wood blades on a circular saw and pop rivet everything.</p></blockquote><p></p>
[QUOTE="smackdaddy53, post: 366094, member: 10154"] 1/8" aluminum is what you need. Sure it is more expensive but not bad considering it will last forever. I see a lot of plywood used in builds but I don't care what you put on it it will eventually rot and you will be doubling up on labor. The best thing about aluminum is you can cut it with wood blades on a circular saw and pop rivet everything. [/QUOTE]
Boat House
Sureply plywood
