Motors
Tachometer
<blockquote data-quote="Pappy" data-source="post: 332789" data-attributes="member: 3278"><p>There will be no yellow/gray at the console.</p><p>That wire changes to a solid gray in the boat harness and terminates at the console or dash. That is your tach. wire. </p><p>In addition you will need to pull key on power from the key switch or another instrument. That wire color will be purple.</p><p>Add your ground (black) and you are done. </p><p>If you want instrument lights then the wire color is blue.</p></blockquote><p></p>
[QUOTE="Pappy, post: 332789, member: 3278"] There will be no yellow/gray at the console. That wire changes to a solid gray in the boat harness and terminates at the console or dash. That is your tach. wire. In addition you will need to pull key on power from the key switch or another instrument. That wire color will be purple. Add your ground (black) and you are done. If you want instrument lights then the wire color is blue. [/QUOTE]
Motors
Tachometer
