Boat House
Temporary prop repair with JB weld?
<blockquote data-quote="KMixson" data-source="post: 142271" data-attributes="member: 432"><p>What if it breaks loose and puts hole in the hull? How much is the hull worth compared to a new prop? What if it destroys the seals, which then destroys the bearings causing the lower unit to lock up twisting the drive shaft in two and bends the connecting rods? How much is a prop compared to new motor?</p></blockquote><p></p>
[QUOTE="KMixson, post: 142271, member: 432"] What if it breaks loose and puts hole in the hull? How much is the hull worth compared to a new prop? What if it destroys the seals, which then destroys the bearings causing the lower unit to lock up twisting the drive shaft in two and bends the connecting rods? How much is a prop compared to new motor? [/QUOTE]
Boat House
