Off The Water
Watering Hole
Test Picture
<blockquote data-quote="Alphawolf" data-source="post: 96141" data-attributes="member: 3"><p>I would bet it has something to do with your corporate connection limiting the amount of time a request can be made on the internet before being completed (that's why you continue to see the popup, which is actually an animated gif, during the error. The popup is then terminated after the script is done uploading the attachment). As it seems to be just for you, I can only assume this to be the case because I can't reproduce it and no one else is stating they are having the same problem. </p><p></p><p>FWIW, the settings on this server are set to stop any script after running for 60 seconds.</p><p></p><p>Sorry. <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite3" alt=":(" title="Frown :(" loading="lazy" data-shortname=":(" /></p></blockquote><p></p>
[QUOTE="Alphawolf, post: 96141, member: 3"] I would bet it has something to do with your corporate connection limiting the amount of time a request can be made on the internet before being completed (that's why you continue to see the popup, which is actually an animated gif, during the error. The popup is then terminated after the script is done uploading the attachment). As it seems to be just for you, I can only assume this to be the case because I can't reproduce it and no one else is stating they are having the same problem. FWIW, the settings on this server are set to stop any script after running for 60 seconds. Sorry. :( [/QUOTE]
Off The Water
Watering Hole
Test Picture
