Motors
Throttle Cable Compatability
<blockquote data-quote="srr5008" data-source="post: 352657" data-attributes="member: 4287"><p>I am replacing a 95 mercury outboard with a 98 evinrude. I want to know if I can reuse my mercury throttle cables? They have the same ends, and the length of my existing cables will work for the evinrude. </p><p></p><p>The existing mercury cables look like this:</p><p>https://www.iboats.com/images/teleflex/control_cables/large/type600a_cc635_ob_big.gif</p><p></p><p>The evinrude cables look like this:</p><p>https://www.iboats.com/images/teleflex/control_cables/large/cc636_ob_big.gif</p><p></p><p>The only difference, and I am not sure if this can be fixed, is the plastic adjustment pieces that are located on the threaded portion of the cables. The mercury cables have a plastic cylinder, and the evinrude cables have a plastic wheel. Is there any way to get these cables apart to switch the adjustment pieces?</p></blockquote><p></p>
[QUOTE="srr5008, post: 352657, member: 4287"] I am replacing a 95 mercury outboard with a 98 evinrude. I want to know if I can reuse my mercury throttle cables? They have the same ends, and the length of my existing cables will work for the evinrude. The existing mercury cables look like this: https://www.iboats.com/images/teleflex/control_cables/large/type600a_cc635_ob_big.gif The evinrude cables look like this: https://www.iboats.com/images/teleflex/control_cables/large/cc636_ob_big.gif The only difference, and I am not sure if this can be fixed, is the plastic adjustment pieces that are located on the threaded portion of the cables. The mercury cables have a plastic cylinder, and the evinrude cables have a plastic wheel. Is there any way to get these cables apart to switch the adjustment pieces? [/QUOTE]
Motors
