Electrical
tm troubleshooting
<blockquote data-quote="thedude" data-source="post: 465601" data-attributes="member: 23372"><p>you may experiment with a different TM prop. Verify that depth is no problem and the prop is not ventilating or too close to surface. You are border lined under powered in my view. when i use my 45 lb edge on a tracker 175 is always on #5 speed as well. </p><p></p><p>agree with others that adding another battery will solve none of the symptoms you have.</p></blockquote><p></p>
[QUOTE="thedude, post: 465601, member: 23372"] you may experiment with a different TM prop. Verify that depth is no problem and the prop is not ventilating or too close to surface. You are border lined under powered in my view. when i use my 45 lb edge on a tracker 175 is always on #5 speed as well. agree with others that adding another battery will solve none of the symptoms you have. [/QUOTE]
Electrical
tm troubleshooting
