Off The Water
Watering Hole
to seal or not to seal...?
<blockquote data-quote="hoosier78" data-source="post: 302808" data-attributes="member: 10681"><p>Absolutely seal! If you use 2 pieces of exterior rated plywood glued together [thickness of plywood depends on thickness of existing transom] with outdoor wood glue, then coated on all exposed surfaces with a good spar 3 times, I will last a long time. </p><p>If you dont coat it, its shot in a couple years.</p></blockquote><p></p>
[QUOTE="hoosier78, post: 302808, member: 10681"] Absolutely seal! If you use 2 pieces of exterior rated plywood glued together [thickness of plywood depends on thickness of existing transom] with outdoor wood glue, then coated on all exposed surfaces with a good spar 3 times, I will last a long time. If you dont coat it, its shot in a couple years. [/QUOTE]
Off The Water
Watering Hole
