Tracker 1542 build questions
<blockquote data-quote="onthewater102" data-source="post: 458070" data-attributes="member: 13702"><p>Welding aluminum doesn't guarantee longevity. Finding a welder who does quality work at a workable price is hard enough, but welded aluminum boats are made from thicker materials and designed around the propensity of aluminum to stress cracking. Take a riveted boat with a thinner skin and drop a welded frame in it and you're asking for cracks to form over time in the sheet metal around the areas where the welds stiffen the hull.</p><p></p><p>I say if you've got a riveted hull use rivets in your build unless you have the engineering prowess to work around aluminum's kwirks.</p></blockquote><p></p>
[QUOTE="onthewater102, post: 458070, member: 13702"] Welding aluminum doesn't guarantee longevity. Finding a welder who does quality work at a workable price is hard enough, but welded aluminum boats are made from thicker materials and designed around the propensity of aluminum to stress cracking. Take a riveted boat with a thinner skin and drop a welded frame in it and you're asking for cracks to form over time in the sheet metal around the areas where the welds stiffen the hull. I say if you've got a riveted hull use rivets in your build unless you have the engineering prowess to work around aluminum's kwirks. [/QUOTE]
