Boat House
Tracker 1542 Live Well Idea and need help.
<blockquote data-quote="BaitCaster" data-source="post: 181506" data-attributes="member: 2895"><p>You could install one of these pumps through the thru-huill fitting in the drain on the bottom and it ouwld pump your well full - https://www.cabelas.com/product/Johnson-Pump-Cartridge-Livewell-Pumps/737730.uts?Ntk=AllProducts&searchPath=%2Fcatalog%2Fsearch.cmd%3Fform_state%3DsearchForm%26N%3D0%26fsch%3Dtrue%26Ntk%3DAllProducts%26Ntt%3Dlivewell%2Bpump%26WTz_l%3DHeader%253BSearch-All%2BProducts&Ntt=livewell+pump&WTz_l=Header%3BSearch-All+Products</p><p></p><p>However, drainage would then be an issue. You could run an overflow pipe through the seat and out the side of the boat for drainage.</p><p></p><p>I thought about doing this, but it required too much cutting of my boat. I fill my livewell with the garden hose before I leave the house (I treat the water with a chlorine neutralizer). Alternatively I also have a collapsable bucket that I sometimes use to fill it.</p></blockquote><p></p>
[QUOTE="BaitCaster, post: 181506, member: 2895"] You could install one of these pumps through the thru-huill fitting in the drain on the bottom and it ouwld pump your well full - https://www.cabelas.com/product/Johnson-Pump-Cartridge-Livewell-Pumps/737730.uts?Ntk=AllProducts&searchPath=%2Fcatalog%2Fsearch.cmd%3Fform_state%3DsearchForm%26N%3D0%26fsch%3Dtrue%26Ntk%3DAllProducts%26Ntt%3Dlivewell%2Bpump%26WTz_l%3DHeader%253BSearch-All%2BProducts&Ntt=livewell+pump&WTz_l=Header%3BSearch-All+Products However, drainage would then be an issue. You could run an overflow pipe through the seat and out the side of the boat for drainage. I thought about doing this, but it required too much cutting of my boat. I fill my livewell with the garden hose before I leave the house (I treat the water with a chlorine neutralizer). Alternatively I also have a collapsable bucket that I sometimes use to fill it. [/QUOTE]
Boat House
