Boat House
Transom Material Help
<blockquote data-quote="BigTerp" data-source="post: 278624" data-attributes="member: 9169"><p>I'm working on replacing my transom as well. Mine is 1-1/4" thick. Try finding 5/8" marine plywood :x . What I was able to find, relatively easy, was AC exterior grade fur, un-treated. I found this at the first local lumber company I called. I'd imagine you'd have several in your area. Google lumber yard or something similar, and you should be able to find what you need within a few calls. Also, epoxy resin or fiberglass will make that transom last longer than spar urethane will.</p></blockquote><p></p>
[QUOTE="BigTerp, post: 278624, member: 9169"] I'm working on replacing my transom as well. Mine is 1-1/4" thick. Try finding 5/8" marine plywood :x . What I was able to find, relatively easy, was AC exterior grade fur, un-treated. I found this at the first local lumber company I called. I'd imagine you'd have several in your area. Google lumber yard or something similar, and you should be able to find what you need within a few calls. Also, epoxy resin or fiberglass will make that transom last longer than spar urethane will. [/QUOTE]
Boat House
