Boat House
Transom thickness/one or two pieces of plywood?
<blockquote data-quote="surfman" data-source="post: 447743" data-attributes="member: 7404"><p>Pretty much all manufactures will laminate two pieces together, 1" thick and thicker ply wood is made but, not usually readily available, there is nothing wrong with gluing two pieces together, it is simply glue together veneers anyway. Most of the transoms I have seen are a minimum 1.5” thick, two pieces of 0.75” plywood laminated together.</p></blockquote><p></p>
[QUOTE="surfman, post: 447743, member: 7404"] Pretty much all manufactures will laminate two pieces together, 1" thick and thicker ply wood is made but, not usually readily available, there is nothing wrong with gluing two pieces together, it is simply glue together veneers anyway. Most of the transoms I have seen are a minimum 1.5” thick, two pieces of 0.75” plywood laminated together. [/QUOTE]
Boat House
