Boat House
Trim tabs and transom plates?
<blockquote data-quote="surfman" data-source="post: 426733" data-attributes="member: 7404"><p>Before I did any of that I would try to rearrange the weight in the boat, weight distribution in a small boat is a huge factor.</p><p></p><p>A transom plate will enable you to raise the motor if it is mounted too low and will also provide some set back which will enable higher mounting as well. Good for more clearance but also the further the motor is in the water the more drag there is as well.</p></blockquote><p></p>
[QUOTE="surfman, post: 426733, member: 7404"] Before I did any of that I would try to rearrange the weight in the boat, weight distribution in a small boat is a huge factor. A transom plate will enable you to raise the motor if it is mounted too low and will also provide some set back which will enable higher mounting as well. Good for more clearance but also the further the motor is in the water the more drag there is as well. [/QUOTE]
Boat House
