Motors
trolling motor dilema
<blockquote data-quote="Pappy" data-source="post: 387087" data-attributes="member: 3278"><p>Well....if it helps, I run a 45# MG on my 15'6" fiberglass Gheenoe Classic with good results. </p><p>If you want to place your batteries anywhere else in your boat, do it. No (significant) loss as long as you run sufficient cables. You stated running them somewhere else with extension cables would drop your amps. Not so if you simply do it right.</p></blockquote><p></p>
[QUOTE="Pappy, post: 387087, member: 3278"] Well....if it helps, I run a 45# MG on my 15'6" fiberglass Gheenoe Classic with good results. If you want to place your batteries anywhere else in your boat, do it. No (significant) loss as long as you run sufficient cables. You stated running them somewhere else with extension cables would drop your amps. Not so if you simply do it right. [/QUOTE]
Motors
