Electrical
Trolling Motor only goes 2mph on 14' v-hual - Is that good ?
<blockquote data-quote="MtnDew" data-source="post: 301745" data-attributes="member: 10632"><p>Thanks for the info guys.</p><p></p><p>I keep playing with the transducer .. kind of a pain to go out, go back to trailer etc.. I am trying to find the balance between the rooster tail, getting depth on plane and being able to use outboard to scan.</p><p></p><p>I went to a smaller less busy lake today, and left the trailer at the ramp and just kept going in and out making small adjustments. BUT THE one thing I was not changing was the angle of the unit. It is parallel to the hull with maybe a slight tilt towards the boat so the rear of the unit furthest from the transom is a tad lower then the front.</p><p></p><p>I may try one more click to tilt it.</p><p></p><p>thanks again, I had gotten focused on up and down.</p></blockquote><p></p>
[QUOTE="MtnDew, post: 301745, member: 10632"] Thanks for the info guys. I keep playing with the transducer .. kind of a pain to go out, go back to trailer etc.. I am trying to find the balance between the rooster tail, getting depth on plane and being able to use outboard to scan. I went to a smaller less busy lake today, and left the trailer at the ramp and just kept going in and out making small adjustments. BUT THE one thing I was not changing was the angle of the unit. It is parallel to the hull with maybe a slight tilt towards the boat so the rear of the unit furthest from the transom is a tad lower then the front. I may try one more click to tilt it. thanks again, I had gotten focused on up and down. [/QUOTE]
Electrical
