Motors
Trouble starting engine
<blockquote data-quote="richg99" data-source="post: 280148" data-attributes="member: 4376"><p>REPLACE THE PLUG.....</p><p></p><p>It is the least costly and easiest thing to do. Be sure to set the gap correctly. I cannot tell you how many times my engine ( 40 hp 2 cycle Yamaha) gave me trouble and replacing the plug solved the problem. </p><p></p><p>If that doesn't work, but the engine turns over...squirt a little fuel into the chamber and pull. If it doesn't fire, you have some other issue ( probably no spark) Rich</p></blockquote><p></p>
[QUOTE="richg99, post: 280148, member: 4376"] REPLACE THE PLUG..... It is the least costly and easiest thing to do. Be sure to set the gap correctly. I cannot tell you how many times my engine ( 40 hp 2 cycle Yamaha) gave me trouble and replacing the plug solved the problem. If that doesn't work, but the engine turns over...squirt a little fuel into the chamber and pull. If it doesn't fire, you have some other issue ( probably no spark) Rich [/QUOTE]
Motors
