Boat House
Water pipe insulation for protectin wire and cables, anyone
<blockquote data-quote="clarkbre" data-source="post: 189371" data-attributes="member: 2634"><p>The whole point is that the foam isn't the pipe and doesn't carry water. The foam helps to protect and insulate existing water pipes from freezing.</p><p></p><p>In a boat/wire application, i agree with others that the plastic wire loom would work better. I don't think the foam would handle UV light very well and would easily break down over time. The wire loom is built with wiring in mind. It protects and organizes the wires and is built for auto/marine applications.</p></blockquote><p></p>
[QUOTE="clarkbre, post: 189371, member: 2634"] The whole point is that the foam isn't the pipe and doesn't carry water. The foam helps to protect and insulate existing water pipes from freezing. In a boat/wire application, i agree with others that the plastic wire loom would work better. I don't think the foam would handle UV light very well and would easily break down over time. The wire loom is built with wiring in mind. It protects and organizes the wires and is built for auto/marine applications. [/QUOTE]
Boat House
