Motors
Water pump Gasket Seal and Gasket Adhesive options?
<blockquote data-quote="Pappy" data-source="post: 310475" data-attributes="member: 3278"><p>Just use the standard gasket sealing compound. No silicon is used nor needed. </p><p>The GSC can also be used on the bolt threads as a lubricant and to help deter corrosion.</p></blockquote><p></p>
[QUOTE="Pappy, post: 310475, member: 3278"] Just use the standard gasket sealing compound. No silicon is used nor needed. The GSC can also be used on the bolt threads as a lubricant and to help deter corrosion. [/QUOTE]
Motors
