Motors
what motor should i use.
<blockquote data-quote="Boat2fast" data-source="post: 343103" data-attributes="member: 13358"><p>Spend some more time checking out the powerhead like CCM suggested. That Chrysler is an AUTOLECTRIC model. It's kind of a neat setup. The generator is also the starter. Find a shortshaft parts motor and make one good engine with the right shaft length. If it turns out to be in good shape internally, it will perform well. They were a good design. The lightbulb on top had two functions. It showed the charging system was working and it allowed you to see to bait your hook. The cover has a translucent dome on it. If it's not cracked and broken, be careful with it. Someone out there is dying to find it...might be worth something.</p></blockquote><p></p>
[QUOTE="Boat2fast, post: 343103, member: 13358"] Spend some more time checking out the powerhead like CCM suggested. That Chrysler is an AUTOLECTRIC model. It's kind of a neat setup. The generator is also the starter. Find a shortshaft parts motor and make one good engine with the right shaft length. If it turns out to be in good shape internally, it will perform well. They were a good design. The lightbulb on top had two functions. It showed the charging system was working and it allowed you to see to bait your hook. The cover has a translucent dome on it. If it's not cracked and broken, be careful with it. Someone out there is dying to find it...might be worth something. [/QUOTE]
Motors
