Boat House
What prop? 90 Mercury Pro Team 190Tx
<blockquote data-quote="WVfishnfool" data-source="post: 350684" data-attributes="member: 10364"><p>Only way to know if your tach is right is hook that motor up to a digital diagnostic (computer) device that's calibrated and check the tach against it. Most of these analog tachs are off that's why most guys are getting the SmartCraft gauge and Merc Monitor systems on the new Mercs. They're danged expensive but they're on the money 99.9% of the time. Once you verify your tach is reading correct then start adjusting motor height(keep a check on water pressure) and playing with props. Already seen you're using GPS for checking speed so you're good to go there. Have fun and be safe with it.</p></blockquote><p></p>
[QUOTE="WVfishnfool, post: 350684, member: 10364"] Only way to know if your tach is right is hook that motor up to a digital diagnostic (computer) device that's calibrated and check the tach against it. Most of these analog tachs are off that's why most guys are getting the SmartCraft gauge and Merc Monitor systems on the new Mercs. They're danged expensive but they're on the money 99.9% of the time. Once you verify your tach is reading correct then start adjusting motor height(keep a check on water pressure) and playing with props. Already seen you're using GPS for checking speed so you're good to go there. Have fun and be safe with it. [/QUOTE]
Boat House
