Boat House
What size rivets
<blockquote data-quote="DaleH" data-source="post: 435282" data-attributes="member: 15636"><p>If below the waterline, I'd use solid rivets. You could use a good 'closed end' pop rivet up higher, if a good high strength (shear) one.</p><p></p><p>For solid rivets, typically the length of the 'tail l' of the unformed rivet should protrude about 1-1/2 to 2 times the rivet shank diameter from the back side of the surfaces being riveted together. And when bucked or set properly, the tail will expand or 'mushroom' to about 1-1/2 times the rivet shank diameter.</p><p></p><p>It's easy - if you have the tooling. My 12yr old girl re-revited her boat back together, in a few spots, over the weekend. She thought it was great fun!</p></blockquote><p></p>
[QUOTE="DaleH, post: 435282, member: 15636"] If below the waterline, I'd use solid rivets. You could use a good 'closed end' pop rivet up higher, if a good high strength (shear) one. For solid rivets, typically the length of the 'tail l' of the unformed rivet should protrude about 1-1/2 to 2 times the rivet shank diameter from the back side of the surfaces being riveted together. And when bucked or set properly, the tail will expand or 'mushroom' to about 1-1/2 times the rivet shank diameter. It's easy - if you have the tooling. My 12yr old girl re-revited her boat back together, in a few spots, over the weekend. She thought it was great fun! [/QUOTE]
Boat House
What size rivets
