Boat House
which carpet glue for wood flooring?
<blockquote data-quote="Mac" data-source="post: 56861" data-attributes="member: 842"><p>I'm preparing for carpeting also.....used a router to round off the edges, both top and bottom and then will use liquid nails on the edges when doing the carpet and stapling on the bottom. I recommend three coats of an acrylic enamel before putting the carpet down. I'm using the spray adhesive on the flat surface to hold the carpet down, then liquid nailing the edges and underneath where the carpet goes an inch and a half and securing with staples to hold until the nails dry. I think it was a quarter inch roundover bit I used on 5/8 plywood. Worked very well....filling voids in the edge before painting with water putty....easy to apply and sand.</p></blockquote><p></p>
[QUOTE="Mac, post: 56861, member: 842"] I'm preparing for carpeting also.....used a router to round off the edges, both top and bottom and then will use liquid nails on the edges when doing the carpet and stapling on the bottom. I recommend three coats of an acrylic enamel before putting the carpet down. I'm using the spray adhesive on the flat surface to hold the carpet down, then liquid nailing the edges and underneath where the carpet goes an inch and a half and securing with staples to hold until the nails dry. I think it was a quarter inch roundover bit I used on 5/8 plywood. Worked very well....filling voids in the edge before painting with water putty....easy to apply and sand. [/QUOTE]
Boat House
