Motors
Winterized My First Marine Motor: Comment on Sparkplugs
<blockquote data-quote="acolic" data-source="post: 424707" data-attributes="member: 12118"><p>Hi,</p><p></p><p>All I did was:</p><p></p><ul> <li data-xf-list-type="ul"><br /> Added stabilizer to the fuel tank for long term storage.<br /> Started my outboard and let it warm up for about 15 minutes.<br /> Turned it off and took the top cover off and exposed the carburetors.<br /> Turned it back on and started spraying fogging oil into the carburetors.<br /> Unplugged the gas line from the motor and ran it until it died.<br /> Took out each spark plug and sprayed fogging oil into the cylinder.<br /> Replaced the lower body oil</li> </ul><p></p><p>I should have taken the propeller off and greased the end but I ran out of time. Something I will do in the spring.</p></blockquote><p></p>
[QUOTE="acolic, post: 424707, member: 12118"] Hi, All I did was: [list=] Added stabilizer to the fuel tank for long term storage. Started my outboard and let it warm up for about 15 minutes. Turned it off and took the top cover off and exposed the carburetors. Turned it back on and started spraying fogging oil into the carburetors. Unplugged the gas line from the motor and ran it until it died. Took out each spark plug and sprayed fogging oil into the cylinder. Replaced the lower body oil [/list] I should have taken the propeller off and greased the end but I ran out of time. Something I will do in the spring. [/QUOTE]
Motors
