Electrical
wire diagram-
<blockquote data-quote="natemoen" data-source="post: 432279" data-attributes="member: 22242"><p>The wiring diagram seems fine. As for the main circuit breaker, add up the max amperage of all the components in your system add 20% and that should be roughly your main circuit breaker. That breaker should be as close to the battery as possible, if not on it. The reason for the main breaker is to prevent dead shorts in the system usually caused by chaffing of the insulation in the wire before it has any chance to get to a fuse.</p><p></p><p>You need to add all your loads because you need it to be large enough to run everything at once.</p></blockquote><p></p>
[QUOTE="natemoen, post: 432279, member: 22242"] The wiring diagram seems fine. As for the main circuit breaker, add up the max amperage of all the components in your system add 20% and that should be roughly your main circuit breaker. That breaker should be as close to the battery as possible, if not on it. The reason for the main breaker is to prevent dead shorts in the system usually caused by chaffing of the insulation in the wire before it has any chance to get to a fuse. You need to add all your loads because you need it to be large enough to run everything at once. [/QUOTE]
Electrical
wire diagram-
