Motors
Won't pick up fuel
<blockquote data-quote="JKM4874FORD" data-source="post: 278796" data-attributes="member: 9612"><p>This is what we were thinking. If the bowl is full of fuel it should run. We spray fuel in the carb and it will try to run. This leads us to believe it is not sucking fuel into the motor. Stopped up passage maybe. We have been thru this stupid thing several times. all passages look to be clear, carb cleaner blows thru all passages as far as we can see. We may have to resort to taking it to someone. I really did not want to do that. It would be admitting defeat and that would would be bad.</p></blockquote><p></p>
[QUOTE="JKM4874FORD, post: 278796, member: 9612"] This is what we were thinking. If the bowl is full of fuel it should run. We spray fuel in the carb and it will try to run. This leads us to believe it is not sucking fuel into the motor. Stopped up passage maybe. We have been thru this stupid thing several times. all passages look to be clear, carb cleaner blows thru all passages as far as we can see. We may have to resort to taking it to someone. I really did not want to do that. It would be admitting defeat and that would would be bad. [/QUOTE]
Motors
Won't pick up fuel
