Off The Water
Watering Hole
Wood Stove
<blockquote data-quote="JMichael" data-source="post: 291169" data-attributes="member: 7544"><p>The basic Barrel kits can be had for less than $40 and the only other parts you need is a metal barrel and your chimney pipe. The good part about the kits is that the kit parts are made of cast iron so you can keep using those parts and just replace the barrel ever few years. </p><p>https://www.northlineexpress.com/wood-stoves/barrel-stove-kits/vogelzang-standard-barrel-wood-stove-kit-bk100e.html</p></blockquote><p></p>
[QUOTE="JMichael, post: 291169, member: 7544"] The basic Barrel kits can be had for less than $40 and the only other parts you need is a metal barrel and your chimney pipe. The good part about the kits is that the kit parts are made of cast iron so you can keep using those parts and just replace the barrel ever few years. https://www.northlineexpress.com/wood-stoves/barrel-stove-kits/vogelzang-standard-barrel-wood-stove-kit-bk100e.html [/QUOTE]
Off The Water
Watering Hole
Wood Stove
