jpfieber
- Joined
- Jun 13, 2008
- Messages
- 46
- Reaction score
- 1
- LOCATION
- Mequon, WI
I've got the metal of the transom cleaned up pretty well, but I'm a little concerned about the drain. It appears to be a cast iron fitting that's somehow stuck in there. It has remnants of threads on both the inside and outside. It's rusted, and I suspect will eventually cause problems, so now would be the time to replace it with a proper piece. The outer diameter is 1". I haven't looked around for options yet, I would think that brass would be the best material, but not sure if there would be a reaction between that and the aluminum. Anyone else replaced their drain?
One thing I'm thinking is that i want it as low as possible to the floor, don't want to much water left that can't drain out.
![2015-10-20 10.39.11.jpg 2015-10-20 10.39.11.jpg](https://cdn.imagearchive.com/tinboats/data/attachments/67/67911-84a66dcc3f89402814ece79ab1f743e4.jpg)
![2015-10-20 10.39.22.jpg 2015-10-20 10.39.22.jpg](https://cdn.imagearchive.com/tinboats/data/attachments/67/67912-62b7346121b379dfe41c979fc073ee2c.jpg)
