sunnyg
- Joined
- Jul 25, 2023
- Messages
- 5
- Reaction score
- 0
- LOCATION
- Delta Pennsylvania
Hello Friends,
I just got my first boat and feeling some concearn. After a few days with it I'm finding corrosion. I would love to hear your advice on coming up with a plan for repairs.
The boat is a 2003 Duranautic 16' DN-16SST, 2003 Johnson 25hp, and 2022 trailer. It's a welded hull. I got it for 4000$. I bought it from a local shade tree shop that also sells boats on commission.
Issues I found before buying the boat:
So here is where I could use some advice.
My current plan is to do a simple patch over the holes I exposed and enjoy it the remainder of the season. I'll be surprised if I get out 10 more times. I'll be using it in freshwater and parking it under a car port. At the end of the season, I'll take apart the boat and really inspect every inch to evaluate the state of this corrosion. Until then, I want to start doing research and preparing myself for repairs.
For the temporary patches, I've peeled away the loose blisters and junk and cleaned the areas with 50/50 water and cleaning vinegar and brass brush and rinsed well. The pictures I attached are after this cleaning. Next I think I'm going to de-grease the area and apply Flexpaste. I'm considering Flexpaste so I have an slightly easier time removing it to do a better repair later. I have Oshpo, should I use some of that too?
I've been doing as much reading on transom repairs and re-skins as I can. Seems like most people recommend to find a good welder to do the work. Has anyone gone through something similar with a boat repair shop and can share some advice or approximately what this could cost? Any recommendations for a shop near Havre De Grace / Baltimore MD area?
As far as DIY repairs, I'd be willing to try doing what was shown in the video below. He removes all corrosion and sandwiches the skin between two new aluminum sheets with g-flex epoxy and rivets. I'm curious if this would eventually start wicking water between the sheets and start corroding again. Any thoughts?
I'll probably get a quote for welding the hull as well. If I go the DIY route what is considered the best repair apart from welding? I've brazed steel before, but it seems like the general opinion is this isn't a good repair on aluminum boats. Is a sandwich of new aluminum gflex epoxied and riveted a good option?
Or is this all a waste of good money and I should just enjoy it while it lasts and watch classifieds for the next boat lol.
Thank you if you've read all this and have some advice to share. I appreciate your time.
- Wiring was corroded and brittle. Only the motors electric start worked as is.
- Stern wood decking had soft edges.
- Saw a filler patch on the transom, lower starboard side. I was naive and figured it was just an ugly job to fill in unused holes or something.
- Found blisters in the bottom paint, almost all in the rear, but didn't peel anything away
- The transom wood near the live well pump was soft and like dirt. What I can see at the top is still solid.
- The transom had reinforcing plates bolted over. So I suspected plates were added as an easier fix than replacing the wood.
- Under the blistered bottom paint I found layers of silicone, flakes of jb weld or similar, layers or hard yellow stuff, hard light grey stuff, white salty powder, and finally corroded aluminum. The worst area is under the starboard rear bench. Its corroded the entire way through and I can see flotation foam. The exposed hole is about the size of my fingertip.
- I peeled away silicone around the transom wood and plates and found deep pitting right along the edge of the wood. I can see at least one pin hole through the skin.
- I recently found forum posts saying Duranautics of this year used treated ply in the transom that corroded the hull
- the patch on the transom I saw is covering an entire bolt.
- The transom ply has some old seafoam green paint on it. So I think this still has the original and possibly treated plywood.
- I can see some corrosion in the keel weld seam shown in the pictures.
- Thankfully under the rear deck the hull appears good.
- Transom is still stiff. I can't flex it standing on the outboard.
- I fixed a tiny bit of wiring and have a working auto bilge.
- I took it out on the water for an hour and it stayed dry ( this was before I peeled away the blistered bottom paint ).
